OEM Wheel and Tire Information - Page 4 - Hyundai Genesis Forum
 4Likes
post #61 of 107 Old 07-10-2013
brucelee's Avatar
Quoted: 90 Post(s)
Will you be trying a touch up or painting the entire wheel? You'd have to account for paint faiding anyway and a perfect match is going to be near impossible over all, paint the entire wheel and it's problem solved.
2011 Premium Silverstone 2.0T > 2013 Premium Tsukuba Red 2.0T
Webshots http://community.webshots.com/user/bruclee
brucelee is offline
post #62 of 107 Old 07-10-2013
im getting a new wheel entirely so i'll probably leave it as-is if it looks close enough. i'll consider new paint if it starts bothering me. =p
bluelixir is offline
post #63 of 107 Old 04-22-2014
jeanyves's Avatar
Has anyone ever put 245/45 on stock 18's in the front without spacers?
jeanyves is offline
post #64 of 107 Old 05-20-2014
tayco91's Avatar
Quoted: 33 Post(s)
Just the information I was looking for... thanks
tayco91 is offline
post #65 of 107 Old 06-18-2014
sub
_________________
2012 2.0t base auto
Vibrant joiner - silencer delete
ISIS test pipe - second cat delete
rickt is offline
post #66 of 107 Old 07-30-2014
Everyone where links to this damn thread but there's not a single mention of the 2013 R-spec weights. Probably because it's in the 2012 section? So then why are people linking from the 2013 sub forums?
https://www.gencoupe.com/2321737-post3.html
MrDestinE likes this.
27660 is offline
post #67 of 107 Old 10-24-2014
mak127958's Avatar
Quoted: 41 Post(s)
Are the offsets the same for the 2013+?
mak127958 is offline
post #68 of 107 Old 10-27-2014
...4, 3, 2, 1
AMBCoupe's Avatar
Quoted: 253 Post(s)
Yes
2010 Acqua Minerale Blue
2.0T 6MT
Ultimate Racing SRI
Ultimate Racing Down Pipe / Test Pipe
CPe Catback
TurboXS RFL-cold side
AP Clutch Line
Uniq Rigid Collars
Eibach Sportline
Eibach F/R Sway Bars
OEM Strut Bar
BBM Spoiler
JCS Pod
ProSport EVO Boost & Wideband
'13 clutch
Megan tranny mount
Varrstoen ES2 (white)
255/35/19x9.5 +22
275/35/19x10.5 +22
-Built by 10Fintec
-Tuned by BTR
AMBCoupe is offline
post #69 of 107 Old 12-04-2014
I'm getting some winter tires for CHEAP but there's a catch, they are all 255/40/18 Continental ExtremeContact DWS. I have a set of factory 18's from a 2013 Genesis Coupe and need to know the following:
1) Will they even fit on the rim?
2) My 2010 GC Track is completely stock. Will I run into any clearance issues?
I did a few searches and I didn't see anything similar to what I'm doing.
Previous cars:
1993 240SX
1973 Porsche 914 (mmmm dogleg)
1994 Altima
1994 Camry
2006 Mini Cooper S
240turnedGC is offline
post #70 of 107 Old 01-10-2015
cliffsta's Avatar
Quoted: 10 Post(s)
Figured this was a good place to post this question rather than a new thread...
If I were to switch from my non-track 18s to a set of the track 19s and run the factory 19" tires would my traction control throw a fit? The diameter and circumference would increase by .4% up front, while out back the diameter would remain the same (.1% increase in circumference but same diameter... don't know how that works, but that's what the tire calculator says lol).
Just kinda considering a switch to the factory 19s since I figure a lightly-used set could be had much cheaper than something aftermarket. Plus it opens up the option of Brembos
2012 3.8 Grand Touring Gran Premio Grey
-Tint 45/45/20 with 20% eyelid
-Carbon Filter removed
-KDM chrome grille and Wing Emblem
-Yakima rack
-Punch 600.2 amp / 2x Punch P1 10" subs / LC2i
2009 Kawasaki KLX 250S
-Muzzy full exhaust, DJ Jet kit, UNI filter, ProTaper bars, 14/47 sprockets, Pirelli Scorpion Pro ftont / Kenda TrakmasterII rear, TrailTech Vapor, turn signals tucked & rear fender hacked
Originally Posted by inertiamonster View Post
Ah, I get it now, you're a childish moron.
cliffsta is offline
post #71 of 107 Old 01-10-2015
Why so serious, Bro?
GenCoupeGeek's Avatar
Quoted: 1226 Post(s)
There would be no difference.
BTRcc Custom Tuned
"The difference between stupidity and genius is that genius has its limits.
~Albert Einstein
GenCoupeGeek is offline
post #72 of 107 Old 01-11-2015
It's the ratio of diameter f>r that matters not the overall diameter.
post #73 of 107 Old 03-02-2015
Quoted: 276 Post(s)
Wow, a lot of info here! The official fitment thread is more for after market rims and is over 120 pages so it's hard to get info from that thread.
I have a simple question with OEM 18" rims- I'd like to put slightly higher profile tires on the rear with slightly lower profile tires on the front to give the car a little rake, or make it look that way just a subtle little bit. Would that throw off the TC and SC? I'm gong to get Garageline spacers soon to make the rears broader too. I like the classic muscle car look.
Something like F 235-40-18, R 275-50-18 but would the TC/ABS/SC be all screwed up?
I've read about people going up to a 285 for the rears, but I am not sure if they have OEM rims. Lots and lots of info.... too much....
totalled
guybo is offline
post #74 of 107 Old 03-03-2015
I put a rake on a car once and had fuel pickup problems below an 1/8 of a tank.
I think that is too much spread myself between front and rear tire height.
post #75 of 107 Old 05-07-2015
HL 24
coachmartin77's Avatar
I have a 2014 2.0 RSpec and was looking to move from the stock 19" to 20"
I would be moving from 225/40/19 front and 245/40/19 rear
to
225/35 R20 front
245/ 35ZR 20 Rear.
I'm very new to this so I just wanted to get a double check and opinions.
thanks.
coachmartin77 is offline
post #76 of 107 Old 10-03-2015
Mike1983's Avatar
Getting some 235/35 and 255/35 for my OEM R spec wheels Monday. Hope they look good. Kinda want to go with 265/35 but a little scared it will rub.
Mike1983 is offline
post #77 of 107 Old 10-11-2015
fasttallguy's Avatar
I am running 245 front and 285 rear lowered and no issues not running stock rims
2013 3.8 GT M/T
GT custom CAI
GT Custom Ceramic coated Headers
Down pipe&Test Pipe-mandrel and tiged
High Flow Cats
Custom True Dual CBE
GS PnP manifold
GS Phenolic Spacer
QT exhaust
BTR custom tune
Track Style Rear Wing spoiler
RMR rear diffuser
De-badged front/rear emblems
IS CF hood vents
Varrstoen 5.5.2 Hypersilver
F:19x9.5 + 22 245/35/19 Nitto's
R:19x10.5 + 25 285/30/19 Nitto's
Eibach Pro-Kit
RMR CF Sideliners
RMR CF Front Diffuser
Tint rear lights and front
25% Tint
fasttallguy is offline
post #78 of 107 Old 10-24-2015
Dark_Coupe's Avatar
Ok so I'm hoping someone can check my math here. The previous owner of my car, who I refer to as "moron", put a terrible wheel/spacer/tire setup on the car. First problem I'm solving is the spacers which are not hubcentric and cause me a lot of vibration at high speed. The wheels both have a 40mm offset. I want to get my wheels fairly flush and I like the 20/20 spacer setup I've seen on a lot of the cars on here. Since I'm under the impression that the stock wheels are a 35mm offset, and provided the aftermarkets are the same width as stock, would I need a 25/25 spacer setup to achieve the same effect? Thanks for any help.
Edit: Also just realized the wheel center bore is bigger than oem, gotta fix that too *sigh*
2012 Bathurst Black R-Spec
CNT Catback
R2C Cold Air Intake
R2C TB Spacer and Gasket
ISIS STS w/ 1lb Weighted Shift Knob
RoadRuns Grill
20" Motiv Magellan 409mb wheels
LED Replacement
Dark_Coupe is offline
post #79 of 107 Old 02-17-2016
Adrian103's Avatar
Quoted: 32 Post(s)
I have a question kinda similar to cliffsta. I was wondering if the r spec bk1 wheels would fit a premium bk2 without any issues? I read earlier in the thread that the bk1 wheels and bk2 wheels differ slightly so I thought i'd ask before I bought them.
Adrian103 is offline
post #80 of 107 Old 02-17-2016
inertiamonster's Avatar
Quoted: 670 Post(s)
Yes, they'd fit no problem.
2013 3.8 Track Pearl White
inertiamonster is online now
Vibrations between 75-85 MPH silvergc Wheels, Tires and Brakes 2008-2012 226 10-04-2019 05:41 PM
An Idiot's guide to 19x9.5/10.5 Wheels, BC Coilovers, and aggressive tire fitment Vacmurse Wheels, Tires and Brakes 2013 and up 4 03-14-2016 08:56 PM
My Wheel Journey! HjunG7i General Discussion 54 04-25-2013 03:43 AM
Winter Tire Info 2011-2012 -from apa.ca yellowmp5 Ontario 8 10-19-2011 05:13 PM
