Brake caliper issue. - Hyundai Genesis Forum
post #1 of 6 Old 07-20-2018 Thread Starter
K1NGLFL1P's Avatar
Yesterday, I had to replace 2 wheels studs that were stripped. I had to step on the brake several times during the install of the new studs to adjust the hub to make it easier on me. Unfortunately, the caliper was off the rotor at this point and I think I pressed the brakes to many times and over extended the piston.
Now, everything is back in place, however, the piston doesn't want to decompress so that I can slide it over the rotor. I've tried releasing the bleeder valve to see if that would work but it still won't budge. Has anyone ever run into this? Is there a fx or am I looking to have to replace a seized caliper
K1NGLFL1P is offline
post #2 of 6 Old 07-20-2018
Rebuild or replace the caliper. Sounds like the piston went past the seal rings and is jammed trying to go back over it. Hyundai brakes or Brembos?
post #3 of 6 Old 07-20-2018 Thread Starter
K1NGLFL1P's Avatar
Damn I kinda figured. But they are the standard Hyundai brakes
post #4 of 6 Old 07-20-2018
Quoted: 247 Post(s)
My only suggestion would be a large C clamp and somthing flat and solid to push the pistons SQUARELY back into their bores, if their not square with the bore their not going in and they will get damaged if forced.
lvdukerider is offline
post #5 of 6 Old 07-20-2018 Thread Starter
K1NGLFL1P's Avatar
tried that. i used a a rather large c clamp and placed a brake pad against the piston to distribute pressure evenly against the piston and still nothing. a friend suggested i leave the cap off the fluid reservoir and loosen the bleeder valve again in hopes that it might relieve more pressure letting me put it back in place. otherwise, i feel like I've tried everything else.
post #6 of 6 Old 07-21-2018
They aren't hard to rebuild. I would take it off first, then force the piston out with some compressed air; beware your fingers. Then try and push the piston evenly back in.
Brake Fluid Disappeared/Potential Caliper Issue? [Long Post] jimmybonez Wheels, Tires and Brakes 2008-2012 22 11-15-2016 10:54 AM
brake caliper size racerb Wheels, Tires and Brakes 2013 and up 3 03-11-2013 03:07 PM
Brake Caliper Help Pesci Wheels, Tires and Brakes 2008-2012 5 08-08-2012 03:04 PM
Caliper painted black with G2 caliper paint Jm_Dug Wheels, Tires and Brakes 2008-2012 20 04-24-2011 01:22 PM
Brake caliper paint. coupeaholic North West 16 06-01-2010 10:42 AM
