Non-Brembo Rear Brakes - Hyundai Genesis Forum
post #1 of 9 Old 08-03-2018 Thread Starter
Quoted: 17 Post(s)
I was able to replace my front brake pads and rotors, but need to get the rears done. The brakes on my 2012 3.8L are non-Brembos. The rears seem a little more complicated of a job than the fronts. Any tips on getting this job done from those who have done it?
In particular I'm concerned about the bottom caliper bracket bolt. Will it come out without having to move any part of suspension? Also, how will I know if I've torqued it enough with just a combination wrench? I'm used to using a torque wrench for tightening down bolts.
Second, do I need to mess with the parking brake adjuster to do this job? Just want to make sure I can get the rotors off.
sa41 is online now
post #2 of 9 Old 08-03-2018
Quoted: 746 Post(s)
you just change the pads and rotors.
The "drum" section of the rear brakes (under the hat of the rotors) are just what the handbrake uses to hold the wheels.
So before you remove the rear rotors, make sure the hand brake is down.
post #3 of 9 Old 08-04-2018
Quoted: 36 Post(s)
And you may want to "loosen up" the e-brake shoes as they can catch...Don't ask me how I know...
ominousone
ominousone is offline
post #4 of 9 Old 08-04-2018
And when you put the rotors back on make sure you put the access hole over the star wheel.
post #5 of 9 Old 08-04-2018 Thread Starter
Quoted: 17 Post(s)
Will a regular screwdriver work for turning the star wheel? I took a peek inside the hole and thought it would look fairly obvious, but I'm having trouble locating the star wheel. I might need to look harder though.
sa41 is online now
post #6 of 9 Old 08-04-2018
There is a oval rubber plug on the rotor hat at 12 oclock. Remove this and inside is the star wheel. Use a flat blade screwdriver and turn it towards you to loosen.
post #7 of 9 Old 08-04-2018 Thread Starter
Quoted: 17 Post(s)
Thanks, I was able to see the gray star wheel after taking off that rubber plug.
I think I remember you mentioned torque wrenches being overrated in another thread. I have a 17 mm combination wrench for the caliper bracket bolts since I can't get a socket and wrench down there. These have a torque spec of 58 to 72 lb-ft. How do you "know" when you're within the range?
sa41 is online now
post #8 of 9 Old 08-04-2018
Get it snug and two more tugs. A ratcheting box end is the wrench to have.
post #9 of 9 Old 08-04-2018
Quoted: 746 Post(s)
Reverse the car in a parking lot at idle speed
With the car in neutral, pull the hand brake
The drums auto adjust when you do this.
WTB: Stock Springs/Shocks & Non Brembo Brakes fuelculture Want to Buy 1 08-07-2014 05:32 PM
Rear calipers with brembo brakes myurina Suspension 2008-2012 3 07-21-2013 06:17 AM
Life of non brembo brakes darvesh88 Wheels, Tires and Brakes 2008-2012 7 01-10-2011 09:03 PM
new thread: non-brembo brakes now shipping! [email protected] Wheels, Tires and Brakes 2008-2012 17 06-16-2010 09:07 AM
17" wheels WILL fit on non-brembo brakes dogstar Wheels, Tires and Brakes 2008-2012 9 04-12-2009 12:45 PM
