Does brake fluid in the clutch lines mix with the brake lines? - Hyundai Genesis Forum
  • 1 Post By JibbelSandwich
post #1 of 3 Old 10-05-2018 Thread Starter
JibbelSandwich's Avatar
Quoted: 24 Post(s)
So, I just got my brakes flushed and upgraded to Motul RBF600. If I didn't also bleed and flush the clutch, will the old fluid from the clutch mix into the reservoir and brake lines, rendering the upgrade worthless? Of course I didn't think about this until after it's all done.
The car has only been driven about 5 feet forward and backward, so the brakes and clutch have been engaged even if only by a little.
2010 Genesis 2.0T R-Spec
2005 Sentra Se-r Spec V
JibbelSandwich is offline
post #2 of 3 Old 10-06-2018
It's all coming from the same reservoir. They do not 'mix' though with normal use. So bleed the clutch and top off with the new fluid.
post #3 of 3 Old 10-06-2018 Thread Starter
Quoted: 24 Post(s)
Okay I just bled the clutch and there was a lot of air in it. I honestly thought I was doing it wrong cause the liquid was coming out in spurts with a lot of bubbles. But after many cycles liquid came out normal with no bubbles. The fluid didn't seem dirty at all also.
So, I drove it around and the clutch feels much smoother; the pedal feel and engagement.
Red Raspberry likes this.
Transmission Fluid and Rear Differential Fluid Change Astrick117 Engine and Drivetrain 24 04-24-2019 04:55 PM
Trans fluid/diff fluid/5th gear grind. zechaj Drivetrain 9 03-23-2015 10:23 AM
Washer Fluid light ON. Fluid FULL ajh1031 3.8 V6 Discussion 2008-2012 2 07-27-2014 09:11 AM
Hawk HP+ Pads, Stoptech Stainless Steel lines, and ATE Super Blue brake fluid install Sieldan Wheels, Tires and Brakes 2008-2012 17 12-10-2011 03:30 PM
Frixa Brake pads & stainless Brake & clutch lines SoCalturbo Suspension 58 09-13-2011 06:41 PM
