Steering Wheel Shake when hitting 65mph+ - Hyundai Genesis Forum
  • 1 Post By shorttrack
post #1 of 9 Old 06-05-2019 Thread Starter
Just recently swapped out my suspension for BC br coilovers. Every since doing that, when hitting speeds of around 65 mph my steering wheel begins to shake. To it to a shop to get an alignment and they said the alignment was fine. Not sure what else is causing it.
kelso1021 is offline
post #2 of 9 Old 06-05-2019
Quoted: 748 Post(s)
wheel bearings, wheel weight(s) flying off, rotors, or tires out of round.
post #3 of 9 Old 06-07-2019
shorttrack
Quoted: 381 Post(s)
Go past 65mph and hold it at 70mph plus .Just kidding ,what AKGC said .
shorttrack is offline
post #4 of 9 Old 07-24-2019
Found alignment specs were the problem for me with this. Eliminate the obvious of wheel balance and warped rotors first. Then consider taking at least 1degree of castor out of the factory specs down to 6-6.5 versus factory 7-8. The steering is way more lively and responsive too and no more 65mph vibration. Also recommend a race/speed shop for the alignment as I've had far too many bad setups at cheaper places.
Greg Klassen is offline
post #5 of 9 Old 07-24-2019
Quoted: 748 Post(s)
How did you do that?
Caster isn't adjustable, unless you tweak the k-member, stock.... unless you have aftermarket control arms.
post #6 of 9 Old 07-24-2019
Alignment shop originally rigged some of the connections with spacers etc to get the caster reduction. Now doing it via Parts Shop Max coilovers that were recently installed and have a high range of adjustability for caster and camber through the adjustable top hat. So worth the money!
post #7 of 9 Old 07-25-2019
Try rebalancing your wheels?
puertoazn is offline
post #8 of 9 Old 07-26-2019
Quoted: 748 Post(s)
On mine, the tires were slightly out of round.
I pump all 4 to about 38 psi in the spring.
Pretty sure the hotter summer temps helped.
Haven't had the need to run it over 70+ mph, but anywhere below that it's fine. Maybe an almost unnoticeable vibration closer to 70
These are Hankook ventus evo "whatever the newer version is". I don't blame the tires, I blame the tire shop for storing them stacked on the treads for too long.
post #9 of 9 Old 07-26-2019
shorttrack
Quoted: 381 Post(s)
Don't go past 64 mph .
br2 likes this.
