Spacers Thread! - Page 36 - Hyundai Genesis Forum
 5Likes
post #701 of 717 Old 05-07-2015
Membrah
GenBrah's Avatar
Quoted: 28 Post(s)
did you cut back the tab on the rear bumper inside your rear wheel wells? its a common piece that will rub on a lowered car that has spacers on it. Do some thread surfing and youll find it.
Go Fast 2006 Triumph Daytona 675
2013 Caspian Black 2.0T R-spec
TurboXs Race Pipe-Agency Power Clutch Line-Garageline 20/25 spacer-Magnaflow CBE-ATQ SS & Bushings-DD led and HID and switchback-PBM coils & RLCA-UNIQ Perf swaybars-Synapse bov-K&N drop in-Megan Tranny Mount
GenBrah is offline
post #702 of 717 Old 05-07-2015
TRob6975's Avatar
Originally Posted by OG_GENESIS View Post
The ride is a bit stiffer than stock from my Rspec; I would do it again. I didn't want to go for the sportlines since I didn't want to restrict the strut travel more than I have to. The prokit gave it a nice drop.
And no I haven't taken any pics on how it looks now.
I have added a few new things, after my spacers, Ima have a shoot.
Look forward to seeing the drop+spacer combo. With your springs do you rub or bottom out? Did you get use to rougher ride fairly quicksilver?
When I first bought my gen I had to get use to the stiffer suspension but it disappeared after a few days.
TRob6975 is offline
post #703 of 717 Old 05-07-2015
Vacmurse's Avatar
Quoted: 688 Post(s)
I'm not finding it, though I'm tired and searching on my phone. Are you talking about cutting out the wheel well liner?
2015 Ultimate 3.8T 8AT (415 whp / 420 wtq)
Go: Precision 6266BB @ 7.9 psi, TB bored (83mm), PNP IM
Safely: AEM Meth injection, Custom Saikou Michi catch cans
Precisely: Enthuspec Subframe collars, Eibach sway bars, BC coilovers, Work D9R 19x9.5 +23 (255/35) 19x10.5 +23 (285/35)
Breakin' Necks: DD Tail as Turn, Hyper G, Gemini Hood, Hydro dip!
Vacmurse is offline
post #704 of 717 Old 05-07-2015
OG_GENESIS's Avatar
Quoted: 116 Post(s)
Spacers Thread!
Yep, you get used to it but then again it's still there. Where I live I don't have any bad roads. When I do go out to LA the drive is more rough but manageable.
I've had it for about a week so far and have yet to be even close to bottoming out. I also have speed bumps where I live and I go straight into them, no scrape but slowly even with my ark exhaust.
Couldn't have expected more from the springs.
TRob6975 likes this.
OG_GENESIS is offline
post #705 of 717 Old 05-08-2015
Membrah
GenBrah's Avatar
Quoted: 28 Post(s)
It's on either side of the car let's use the drivers side as an exams. As soon as you look inside the rear wheel well towards the rear of the car it will be where the rear quarter and your bumper meet closest to the outside of the car. Sand that tab down as much as possible. If problem is your fender itself then camber is your friend. I'm running -2 all the way around and have normal wear on all my tires.
Vacmurse likes this.
GenBrah is offline
post #706 of 717 Old 06-17-2015
OG_GENESIS's Avatar
Quoted: 116 Post(s)
Update, the wheel setup sits flush now with minimal poke.
[IMG]FullSizeRender by OMAR GARCIA, on Flickr[/IMG]
post #707 of 717 Old 07-14-2015
Does anyone have any experience with these spacers? 20mm 25mm Hubcentric Wheel Spacers 5x114 3 Hyundai Genesis Coupe 2010 Combo | eBay
chrissy7679 likes this.
2010 3.8 Track, 6 spd manual, Tsubuka Red
sydwys is offline
post #708 of 717 Old 07-18-2015
TRob6975's Avatar
Originally Posted by sydwys View Post
I did some research and all the reviews I can find are positive for all cars they make spacers for. I might get some myself.
TRob6975 is offline
post #709 of 717 Old 07-29-2015
Boss A$$ Bitch
Shilly_Fit's Avatar
Quoted: 37 Post(s)
Has anyone had any problems with Garageline spacers? Do you have to keep torquing the spacers every so miles?
I didn't use a torque wrench to install so the lugs loosened and wheels almost flew off. Going to get a torque wrench today but I want to do this right or not at all.
This may be a stupid question but will torquing the front wheels and spacers spin around no matter what? Is there a way to keep them from spinning while trying to torque them down?
THANKS IN ADVANCE!
Shilly_Fit is offline
post #710 of 717 Old 07-29-2015
inertiamonster's Avatar
Quoted: 670 Post(s)
No issues at all, I check them every oil change and they've never loosened since first installed, installed at 75lbs with a torque wrench.
Two methods for doing the front spacers, have a friend sit in the car and hold down on the brakes, or use a 2x4 about two feet long to hold the wheel from spinning by standing it upright between the ground and one of the lugs, since the wood is soft it won't damage the threads on the lug.
2013 3.8 Track Pearl White
inertiamonster is offline
post #711 of 717 Old 07-29-2015
Boss A$$ Bitch
Shilly_Fit's Avatar
Quoted: 37 Post(s)
Thanks so much! Did you remove dirt/dust/rust off the wheel hub and behind the wheel before install?
post #712 of 717 Old 07-29-2015
Quoted: 670 Post(s)
Mine were clean and rust free so I didn't have to do much, I would at least wipe everything down to get rid of any loose dust and dirt.
post #713 of 717 Old 07-29-2015
Vacmurse's Avatar
Quoted: 688 Post(s)
Torqued at 85 lbs. Never had an issue, even after tracking the car.
Vacmurse is offline
post #714 of 717 Old 04-18-2016
Snoop's Avatar
My gen has a 67.1 hub size and I bought wheels that have a 73.1 bore. They came with hub rings, but my front wheels are rubbing against the brembos. I need two 5 mm spacers but I need spacers that have hub rings attached to them, I'm not sure if these even exist.
How would I go about solving this? I've been researching for hours and I don't know exactly what to buy.
'15 Empire State Gray Gen Coupe 3.8 r-spec 6mt
AirLift Air Suspension
Work VSXX Wheels
M&S front grille
6000k Diode Dynamics HIDs
KS-Style front lip
'96 300ZX
Snoop is offline
post #715 of 717 Old 06-13-2017
NathanBellaire's Avatar
Anyone ever use Squirrelly Performance spacers? I don't want to go buying bad spacers because I've never even heard of the brand.
And also how about RMX? Uniq Performance sells them on their site for $120, where the Eibach ones are $200? If there's nothing wrong with the cheaper alternatives I don't see why not, I just don't want to waste my money on cheaply made parts.
NathanBellaire is offline
post #716 of 717 Old 09-08-2017
Djmrocks123's Avatar
I got a 14 gen, for some reason the back wheels are a little more "out" than the front due to a slightly bigger hub. I have 20mm in the back and 25mm in the front (ichiba V2) I'm not currently lowered but plan to get some PBM coilovers soon (can't stand the wheel gap still)!
2014 2.0T Premium Trim:
Way to many parts to list, so here is a link
to my ride as featured on GCTUNER's website:
https://gctuner.com//index.php?main_page=page&id=54
Djmrocks123 is offline
post #717 of 717 Old 07-19-2018
Hello. New to the forum. I hope someone can help. I have a 2013 R Spec, I would like to put on the Eibach springs with Bilsteins. From what I have read so far it looks like the B8 shocks and struts are the better option. However I can't find anyone that has done this mod without spacers. I have two other cars with same set up and have not had to use spacers. Is it possible to just use the eibachs and bilsteins with stock 19 inch wheels without the spacers?
Thanks for any help.
Troy
tntknc is offline
RMX Hubcentric Wheel spacers BLACK FRIDAY WEEKEND SALE!! [email protected] Wheels & Tires 10 07-18-2016 05:07 AM
Official "SPOTTED" KDM thread fled Media 1489 05-06-2014 04:39 PM
Flylow's mod thread v2 flylow General Discussion 56 04-06-2014 10:27 PM
