FINALLY: Lightweight Konig Oversteer 19x8.5, 19x9.5 - Hyundai Genesis Forum
 7Likes
post #1 of 84 Old 01-14-2015 Thread Starter
andbudzi's Avatar
Quoted: 482 Post(s)
After going thru 10 different rims choices, i bought Konig Oversteer - spun forged.
I wanted style, performance and affordable price. These are the lightest rims for the money, and look good as well. Also, i did not wanted to get rims were i would have to put in negative camber to make them fit.
Front - 19x8.5 et30 = 23.8 lb, Rear - 19x9.5 et25 = 25.1 lb. (compared to 28lb and 30lb OEM)
They are gunmetal metallic, so depending on the light they will look dark silver or hyper silver.
Wheels cost me $654 shipped and came with aluminum hub-centric rings. I am putting OEM rear tires in the front, and bought 265/40 for the rear (eagle supercar g:2 - $120 shipped new each)
Minato and Carlman like this.
andbudzi is offline
post #2 of 84 Old 01-14-2015
PeanutButter's Avatar
Quoted: 135 Post(s)
This look really nice and for so cheap. Looks like you got a good deal. I am looking for that style in black for that price range myself. Did you get them from a specific vendor here?
2010 2.0T Track Bathurst Black Sold
BTR stage 2 / Treadstone / Tanabe / Prosport / R2C / Synapse / CP-E
2013 Camaro LS Silver Ice Metalic Sold
Injen intake, MRT exhaust
2015 Veloster Turbo Blue Totaled
Stock
2013 2.0T Premium AT Catalina Copper Current
Stock for now...
Fund my mods here... https://tinyurl.com/y2rgaw2o
PeanutButter is offline
post #3 of 84 Old 01-14-2015
...4, 3, 2, 1
AMBCoupe's Avatar
Quoted: 253 Post(s)
You going to run spacers to get them flush?
2010 Acqua Minerale Blue
2.0T 6MT
Ultimate Racing SRI
Ultimate Racing Down Pipe / Test Pipe
CPe Catback
TurboXS RFL-cold side
AP Clutch Line
Uniq Rigid Collars
Eibach Sportline
Eibach F/R Sway Bars
OEM Strut Bar
BBM Spoiler
JCS Pod
ProSport EVO Boost & Wideband
'13 clutch
Megan tranny mount
Varrstoen ES2 (white)
255/35/19x9.5 +22
275/35/19x10.5 +22
-Built by 10Fintec
-Tuned by BTR
AMBCoupe is offline
post #4 of 84 Old 01-14-2015 Thread Starter
andbudzi's Avatar
Quoted: 482 Post(s)
they have them in black as well, it is very known online suppler. something something direct
Shitchya likes this.
andbudzi is offline
post #5 of 84 Old 01-14-2015
Quoted: 135 Post(s)
Thanks, Im normally bad at games such as wheel of fortune but I figured it out lol. I think you helped me pick out the new wheels Ill be getting with my tax return!
Stock
Stock for now...
post #6 of 84 Old 01-14-2015 Thread Starter
andbudzi's Avatar
Quoted: 482 Post(s)
With stock camber - ET25 is maximum offset in the rear without rubbing. (With 275 tires and lowered)
Front - ideal /maximum offset is 20 (for close to stock camber +245 tire, lowered), i will be running 5mm spacer in the front to have ET 25.
At current ET30 (front) rim will poke out 11.4 mm further then stock, and will be 1mm closer to the strut, which still fits fine and looks good.
andbudzi is offline
post #7 of 84 Old 01-15-2015
...4, 3, 2, 1
AMBCoupe's Avatar
Quoted: 253 Post(s)
Look forward to seeing them on the car.
I was considering those and coating them white before i got the ES2's...
2.0T 6MT
Ultimate Racing SRI
CPe Catback
AP Clutch Line
Uniq Rigid Collars
Eibach Sportline
OEM Strut Bar
BBM Spoiler
JCS Pod
'13 clutch
Megan tranny mount
255/35/19x9.5 +22
275/35/19x10.5 +22
-Built by 10Fintec
-Tuned by BTR
AMBCoupe is offline
post #8 of 84 Old 01-15-2015
POV Futografee
Tilley's Avatar
Quoted: 36 Post(s)
Not that it matters for you at this point, but the info you stated is wrong. You can run an offset other than +25 in the rear with factory camber... It just depends on the wheel width. And you can also run wider than a 275 tire.... Even lowered.
Not trying to throw you under the bus.... Just don't want faulty info floating around here in case people read this
Jzen16 likes this.
Tilley is offline
post #9 of 84 Old 01-15-2015 Thread Starter
andbudzi's Avatar
Quoted: 482 Post(s)
When you lower your car wheels naturally go more negative in camber, so yes, you can fit more tire (but it only will degrade performance), and yes you can fit lower offset with narrower tires. An i am talking about not rubbing when taking hard turns, not just every day casual driving.
My plan it to set it to stock camber in the back once lowered. Lowered, stock camber, 275 tire - ET25 is ideal (for the back) to not have any issues no mater how hard you throw your car.
This car has 8.5" front ET30, and 9.5" back ET22
andbudzi is offline
post #10 of 84 Old 01-15-2015
POV Futografee
Tilley's Avatar
Quoted: 36 Post(s)
Yes, lowering your car throws off the factory alignment specs (camber, toe, etc.), which is why you're suppose to get an alignment post lowering, to get everything back in to spec.
You can fit a lower offset wheel with a wider wheel/tire as well... not just a more narrow one.
I ran a 255 up front and 285 in the rear, lowered, factory alignment specs, and NEVER rubbed. That includes high speed mountain runs with heavy dips and hair pin turns.
Again, not trying to argue for the sake of arguing... but this is why so many new GC owners are confused when it comes to what wheels/tires will/won't work... because there's too much inaccurate info floating around here.
A lot of it will come down to driver preference and suspension set up as well... but that's a whole other story lol
For reference: my old wheel/tire/suspension set up... 20x9/10.5 +25 on 255/30 and 285/30, lowered on sportlines, factory camber specs. Again, NEVER rubbed.
Jzen16 likes this.
Tilley is offline
post #11 of 84 Old 01-15-2015
Those look gorgeous my tibron brethren, when are you getting tires mounted?
Minato is offline
post #12 of 84 Old 01-16-2015 Thread Starter
andbudzi's Avatar
Quoted: 482 Post(s)
if you drop low enough, metal tab where bumper meets quarter panel will rub.
I will throw on tires once my rear tires get in.
andbudzi is offline
post #13 of 84 Old 01-25-2015
focalgencoupe's Avatar
Quoted: 251 Post(s)
If you wanted to can you just run factory offset tires sizes front and rear?
Are spacers required or fit just fine?
focalgencoupe is offline
post #14 of 84 Old 01-26-2015
POV Futografee
Tilley's Avatar
Quoted: 36 Post(s)
....huh?
Tires don't have offsets....
Tilley is offline
post #15 of 84 Old 01-26-2015
Quoted: 251 Post(s)
....huh?
I meant the wheel offsets the OP bought will they work or need say spacers.
Also will the stock Track or R Spec 19 inch tires sizes work with those rims.
post #16 of 84 Old 01-26-2015
...4, 3, 2, 1
AMBCoupe's Avatar
Quoted: 253 Post(s)
Tires will fit but have stretch
2.0T 6MT
Ultimate Racing SRI
CPe Catback
AP Clutch Line
Uniq Rigid Collars
Eibach Sportline
OEM Strut Bar
BBM Spoiler
JCS Pod
'13 clutch
Megan tranny mount
255/35/19x9.5 +22
275/35/19x10.5 +22
-Built by 10Fintec
-Tuned by BTR
AMBCoupe is offline
post #17 of 84 Old 01-26-2015 Thread Starter
andbudzi's Avatar
Quoted: 482 Post(s)
No, spacers are not needed, and you can even run -2 deg camber if you wanted without issues.
Front rim is only 1mm closer to the strut and rear is 2mm further away from the strut.
The only reason why i am trowing 5mm spacers on the front is because i have them.
Stock tires will work but will be stretched on these rims; stretched tires are spongy in corners - OEM tires are undersize for the car and hinders its performance, why would you stretch them and make the car handle worse.
245 f, 265 r is perfect for cars weight; you can go wider on those rims - 255 f, 285 r - but that is just too much weight and money wasted.
andbudzi is offline
post #18 of 84 Old 01-27-2015
Quoted: 251 Post(s)
Are you going to use the TPS sensors?
And your set up it will not disturb the traction control and stability control systems?
post #19 of 84 Old 01-27-2015 Thread Starter
andbudzi's Avatar
Quoted: 482 Post(s)
Yes I will be using stock TPS and new set up will not disturb traction / stability - diameter diferance between front and back tires is really close to stock.
andbudzi is offline
post #20 of 84 Old 01-27-2015
Looking forward to seeing them mounted, that is a surprising price for what you get.
DerStro is offline
FS: 19x8.5/19x9.5 HD MSR Wheels CrazyCalm Wheels & Tires 1 01-30-2014 07:33 AM
Best stretch with 19x8.5f and 19x9.5r Gnawpurpz Wheels, Tires and Brakes 2008-2012 7 03-21-2013 10:19 AM
Volk GT-V Gunmetal 19x8.5+23 19x9.5+24 xbeyong Wheels & Tires 17 04-11-2012 11:19 AM
WTS 2x 19x8 +35 Konig Lace & 2x 19x8.5 +35 ASA AR9 buruburu Wheels & Tires 0 10-15-2011 02:49 PM
Ft: Xxr 006 19x8.5 19x9.5 seoulchild Wheels & Tires 15 04-28-2011 02:24 PM
