Conservatively larger tires on stock 19'' wheels - Hyundai Genesis Forum
 2Likes
  • 1 Post By Odelagt
  • 1 Post By AKGC
post #1 of 9 Old 04-21-2019 Thread Starter
Dudewonder's Avatar
Hi, my current stock Bridgestone Potenza tires are in need of replacement and I'm looking to get potentially some new Michelin Sport 4S'. I have a 2014 2.0T R-Spec (280WHP/315WTQ) with stock 19 inch wheels and I was thinking of getting slightly wider tires than the stock 225/40/19-245/40/19 for a bit of additional grip. My searches have yielded most people trying to squeeze out the max with some 245 front and 275 rear setups but I'm looking for something more conservative and safer where I don't need to worry about rubbing, spacing and other issues. My car is stock when it comes to wheels and suspension so stock height and offset. I was looking at mostly at 235 front and 255 rear (I'm guessing 40 aspect ration would be the best here) but I could got slightly bigger if larger sizes fit comfortably on the stock wheels. I want to be able to just take the new tires to the garage, have them installed an not have to worry about anything.
That being said, what setup would you recommend? Also, what aspect would you recommend (35 or 40) for the setup?
2014 2.0T R-Spec (MT)
Dudewonder is offline
post #2 of 9 Old 04-21-2019
In Charge of Snacks
Odelagt's Avatar
Quoted: 218 Post(s)
I used to run 235/255 front to rear. There were no fitment issues, and frankly, I like my rubber sticking out well past my outer rim. Curbing wheels is stupid and unnecessary. LOL. But it was a bit edgy and sometimes squirrely. Next set I went bigger. 245/265. And I did this on Ventus V12 evos. Comfy to be sure, but not track worthy, almost scary in some rain or on twisty downhills. But yeah, a mild upsize is feasible.
However, you need to be extra mindful of soft sidewalls. You'll definitely increase tire roll regardless of the tire selection. You could be inducing an additional .5" to 1" of slop side to side, in addition to increasing peak lateral loads on the bead. not ideal. Think of it like a ski boat doubling back and suddenly snapping the rope on an innertuber. A small amount of tire stretch is recommended for performance applications because the tire roll/the load transfer is shorter in distance and time.
So, stay away from the Hankooks and earlier Continentals. They both have gooey comfort-built sidewalls and behave poorly when not under minimal stretch.
Oh, and there's another one for you. You're going to lose some comfort due to the stiffer sidewalls you'll need. Keep that in mind.
'11 3.8 R-spec
Odelagt is offline
post #3 of 9 Old 04-22-2019 Thread Starter
Dudewonder's Avatar
Thanks for the reply. I really appreciate the detailed response.
Given what you said, would you recommend me getting the extra load (XL) version of the Michelin Pilot Sport 4S if I went with 235/255 in order to reduce tire roll? Also, overall, do you thing it was worth the comfort reduction and tire roll to get that bit of extra grip?
post #4 of 9 Old 04-22-2019
In Charge of Snacks
Odelagt's Avatar
Quoted: 218 Post(s)
On the XL, I don't think that will help the sidewall roll as much as it will increase ride harshness. I could be wrong. Also you'll be taking a substantial weight penalty and if the whole tire is more rigid, you'll effectively be reducing your contact patch over the regular version. Personally, I think the regular 4S Michelins(an excellent tire, btw)will bridge the gap best. Budget version would be a Firestone FireHawk Indy 500. Also, 10mm probably isn't enough to even notice outside of a road course. You should be fine.
Sorry to be vague on the 'feel' questions, but it's all totally up to preference. Do you have any experience going back and forth on the same chassis with different sidewall stiffness or ratio? If not, this is as good a time as any to experiment - see where your personal preferences lie.
My car is on 255 and 275 at 35 sidewall ratio. Wheels are 9.5" front and 10" rear. Most older people who ride with me say it's too harsh. But most of my buddie's cars are much harder than mine. I'm on the middle setting for compression on my BC 2ways with their standard rate springs. I'm mentioning all this not to give you a baseline, but to convey all the factors that go into ride quality.
My experience is likely to be so very different from yours based on measurable data AND individual perception that it's effectively useless until we take a ride in one another's cars.
In short, I can only tell you what will happen/what should result from your proposed changes; not how you'll feel about it. My personal opinion is to go as hard as seems logical/affordable, then dial it back or up once you have a feel for things.
'11 3.8 R-spec
Odelagt is offline
post #5 of 9 Old 04-23-2019
Quoted: 683 Post(s)
It's the other way. Less sidewall will make for a harsher ride.
But a larger sidewall will make sidewall flex more apparent.
I would look at user reviews of the tires you are interested in getting at that tire size. Also be aware of what car they have it on.
post #6 of 9 Old 04-23-2019
In Charge of Snacks
Odelagt's Avatar
Quoted: 218 Post(s)
AK, why are you quoting me? LOL, I never said more sidewall height was harsher. Besides, there won't be any larger or smaller sidewalls in his range of selection. A 255/35 Michelin will have the same sidewall height whether it's a 4S or a 4S-XL.
Dude: I should have made this clear before... Wider tires at the same sidewall number means taller sidewalls/more sidewall flex/theoretically more comfort.
I say theoretically, because as a tire grows it becomes heavier. So, while your sidewalls can take more impacts, the increased unsprung mass means they're getting more impact. It can often be a wash, or a net negative.
I missed this part of your question earlier. AK is correct, here. You've mixed it up a bit. If you go with a wider tire at the same sidewall ratio, you'll both go towards less rigid tire cross section geometry(increased side to side slop) and increase the height of the sidewall, essentially making it softer. So you wouldn't get a decrease in comfort, precisely the opposite; you'd get even more impact absorption.
mahrens34 likes this.
'11 3.8 R-spec
Odelagt is offline
post #7 of 9 Old 04-23-2019
Quoted: 683 Post(s)
I thought you meant XL, as extra large, and didn't think you meant a tire model lol
Odelagt likes this.
post #8 of 9 Old 04-30-2019 Thread Starter
Dudewonder's Avatar
Thanks for all the information Odelagt! I ended up going with the 235/40/19XL and 255/40/19XL. I couldn't find the a non-XL version anywhere so they either don't make them regular weight load for those sizes or they just don't have any stock. I couldn't really afford to wait since I'm on a spare right now (one tire was losing air right before I stored it at the beginning of winter) and really need new tires. They should be arriving this week so I'll try to update on my overall impression after a few test drives!
post #9 of 9 Old 05-01-2019
In Charge of Snacks
Odelagt's Avatar
Quoted: 218 Post(s)
Oh, bummer. Well, the 4S is an excellent tire, I'm sure other than your wallet you'll be happy.
'11 3.8 R-spec
Odelagt is offline
Stock wheels, wider tires, do I believe tirerack.com? Geministorm Wheels, Tires and Brakes 2013 and up 10 04-08-2019 10:10 AM
Stock 2011 Track wheels and Tires. NEW! Gogogear Wheels & Tires 0 05-01-2015 01:44 PM
FORGESTAR Wheels Now Available @ THROWDOWN PERFORMANCE!!! Throwdown Wheels & Tires 312 04-02-2015 01:39 AM
4 Stock 18" wheels w/ Mayrun MR500 tires No TPMSs rrmartin1 Wheels & Tires 2 07-10-2014 04:19 AM
using stock tires on aftermarket wheels? amarrero Wheels, Tires and Brakes 2008-2012 14 01-17-2014 04:22 AM
