Ok lady and gent if you have a CNT v3 exhaust and lower...you will scrape on the cat back exhaust no matter what ....Its a good exhaust but for lower gen coupe not so good....
This is the exhaust you get ...
This is how low my car is
In this picture here is were i scrape plus i dented the left side of of the exhaust can......
The middle part of the cat back hits the drive shaft if you hit a good bump or a rut.PLUS IT SCRAPE
So here what i did ....I went to a muffler shop and had them bent it up,then heat it up and pull it down just a bit on the,so that it dose not rub the sh
t out the exhaust hole/bumper
Then getting it heat up and pull down...
Now the way i did it did work to a point....I dont scrape as much on the back end,but if i hit a deep rut or bump or dip in the road it will plus i still scarpe and hit the driver shaft in the middle coming in and out the drive way on a angle cant go str8 due to the front lip and lower...
I got some Torque Solution exhaust mounts ....now i dont know if these will help
but i figure i will try..these are from the Exhaust Mount kit 12mm Mitsubishi Evolution X 2008-11
there the some as stock just coupe..
here are some video of the exhaust
I got some Torque Solution exhaust mounts ....now i dont know if these will help but i figure i will try..these are from the Exhaust Mount kit 12mm Mitsubishi Evolution X 2008-11.....
Ok i install them and i have a cnt CBE,I did fit them on the stock CBE and they fit prefect........I order 12mm and if you have the stock exhaust 12mm is good for you but if you have a aftermarket exhaust i would go with 10mm..............stock 12mm,Aftermarkert exhaust 10mm...this is what i fine works the best for me....these are not made for the gen coupe but they do work
torque solution mount install on stock hanger to cnt CBE
torque solution mount side by side with stock
*****Note i only install the rear hanger mount...i did not install the rest because i figure it all be the same result******
this is a good exhaust and i love it but i might have to go to something else,just my car to low for it...if any want this exhaust pm me i will even add in a cnt test pipe brand new for free...
