201 - 220 of 259 Posts
If its the stock mfs than the wires aren't connected like the PDF shows. I did mine a few weeks ago and have some pictures I can send along side of the PDF. Most of the PDF you can use for the take apart. Let me know if the mFS has the wires on it. If not give me a few days to mark the wiring in the pictures for you.
It does have wires, it has a 3 running from beside the port on the underside of the MFS that go into a single connect. Wires are white, black, and blue, I guess the remote, positive, and negative? I've worked on cars but only done audio wiring haha. I appreciate the help man.
To those who bought the kit off of ebay, the one that comes with the multi-function switch (MFS), is this an actual Hyundai switch or is it an aftermarket switch of some kind? The add says its OEM but its coming from overseas so I just wanted someone who has received this kit and installed it to verify that the parts are Hyundai brand and fit and function correctly. Thanks you for your assistance.
I got mine by itself on eBay and it was the real thing. I'm pretty sure from the PDF of the instructions, they must of soldered in lengths of wire already. I just flipped between the PDF, wiring diagrams, and the threads here I figured out a setup I liked for how I would control them.
My kit came with an OEM MFS and the images on how to install it. I created the famous PDF file that has been circulating around this post with some comments and observations. Nothing spectacular, just helpful.
Anyone needing a copy of it, please PM your email addresss and, while I can, I will email it to you.
i have installed the kit and the MFS is the real deal, fits and works flawlessly. i def recommend the setup. also i have the PDF instructions that have side notes that help with the install. just pm me your personal email and ill forward it to you.
Please send PDF to
b5com@yahoo.com
I just ordered the fog kit with the MFS and hoping to install this weekend.
Thanks
Just view these for fun first.
blowing up air bags
Did you see the one where they put in the couch and sent a guy flying?!
link -->
Any rate thanks guys for the help, I just ordered the kit from ebay with the oem MFS and hopefully I get it right!!:gc-wmscared0016:
**Please Sticky this so we don't have a million more questions on fog lights**
I finally got all the parts together and the time to do it! This will work for the wiring of after market lights as well.
I will list the parts I used, where I got them and what I paid, but you can use what ever works for you.
Parts required:
OEM fog lights: Ebay seller kdmsource.1735 $95.00 shipped.
Fused and relayed HID harness: Ebay seller traderightly $9.99 shipped
**This harness is for HID lights so the plugs do not fit the 881 bulbs, so you will need to get 881 pigtails for the harness, or look for one that has them, but I had no luck**But for 9.99 shipped it is worth it**Or you can build you own!
881 pigtails: While we find your parts, please enter your ZIP Code at CSK Auto $8.59 each
Switch: AutoZone.com | Blue LED rocker switch | Blue LED rocker switch
Connectors and other supplies:
Ring terminals, heat-shrink tubing, heat shrinkable butt connectors, zip ties, self tapping screws and extra wire.
**The above will vary depending on how you want to do you connections, as long as they are weather resistant. You may chose to solder your connections, but heat shrinkable butt connectors work great if you can find them**
Tools: Ramps or jack and jack stands, Screw gun, test light, soldering iron, wire strippers, flush-cut pliers (for zip-ties) crimpers, small socket set and BEER!!! (or beverage of choice)
1. Raise the front of the car to gain access to the underside of the front bumper. Locate and remove the 4 clips (2 on each side) that hold the plastic cover on under the fog lights.
2.Remove the vent-like covers where fog lights go (4 screws each) and install the fog lights in the holes using the same screws.
3.Locate the under hood fuse block and use the POS lead for main power to relay.
3.5. Mount relay and route and secure harness, ground the switch to the ground point near the fuse block. Splice in a length of wire to go through firewall.
4. Route the wires for each light down to the area near the left light, add a ring terminal to the ground side of one pig tail and ground to the body ground near the light.
5. Add a ring terminal to a length of wire to run to the right fog light and ground on the same point as the left, splice-in a length of wire from the harness for the power for the right light and send both across to the right fog and pigtail and splice and seal all connections, secure with zip ties.
6. Use a small screw driver or something similar to open up the grommet for the hood release cable and push the switch wire in from the outside.
7. Tap power for switch from the fuse box (or find and tap wire) for the RT tail light (10amp) ground switch to the metal dash support and connect the wire from the relay to the switch. Test that all is well and mount the switch if desired. I did not mount mine because I will not turn it off much and I did not want a hole in my dash, so I zip-tied it to the OBDII plug bracket so I could get to it if I needed.
Completed and switch location *note blue light at the top of picture*
In this wiring configuration the fog lights will come on with the Autolamps, parking lights or head lights (as long as the switch is on ) and go off when the ignition is turned off.
Great DIY. Perfect install! Thanks!
