ok guys well i just opened up my headlights because they were fogging up and there was a hair on the lens :dunno: so i am going to clean the inside of the lens what should i use to do so thanks
if you want to clean inside the lens then you need to bake it open... if you just want to get rid of the fogs.. take out the signal bulbs and shove a blow dryer in there... it'll dry up the moisture for sure and saves you time baking your lights.. as for the hair... HOW DID IT GET IN THERE THE FIRST PLACE? is what I want to know...
if ur planning on doing any cleaning of the inside of a headlight lens u can use something as simple as distilled water or rubbing alcohol or something with no impurities in it(Vodka ). i'm not sure how finding a hair inside ur headlight warrants cleaning the inside lens but if your gonna do it make sure to use something with no impurities then bake it afterward to remove any moisture and to seal it back up.
Lens cleaner (small bottles are sold for eyewear use) and microfiber towel.
Ha
Related Threads
Hyundai Genesis Forum
posts
2.1M
members
64K
Since
2008
