So what causes the popping sound on the exhaust when revving?
56K views 11 replies 9 participants last post by  WhoaBlackGenny
#1 ·
When i rev my 3.8 i get a popping sound coming from the exhaust right after letting go of the gas, It sounds pretty awesome but i am wondering that causes this to happen? is it a result of too much fuel burning? I know that a lot of other cars don't do this when revving.
Also does the 2.0T do the same thing?
#3 ·
engine is prob going to blow soon. take it to the dealer and complain asap!
#4 ·
mmm I think not. (@jode since flylow posted already....btw...trollololol!)
The 3.8 only really pops when its cold. Doesn't do it hardly if at all once the engine is up to operating temps which is when the headers would be hottest.
I would venture to say that the pop is from the expansion of gas after transitions in the exhaust, namely the pressure gradients before/after the cats. You're causing a massive backpressure wave once you let off the gas and the throttle plate closes. That wave is going to repeatedly propagate the length of the primary and to a lesser extent, the downpipes. The cats contain the majority of the wave, and you get a big pressure gradient across the converters. Once the system heats up there's not as much of a pressure gradient since the hot exhaust is helping to keep EGT therefore velocity higher and it stops popping so much.
Could be wrong... but throttle lift isn't going to cut spark, so I doubt there's much unburnt fuel going into the headers in the first place.
Bottom line is, it's completely normal, don't worry about it. You don't hear it on most cars because of the stock exhaust system. Any car with an open exhaust pops a lot.
#6 ·
Your explaination works for the stock exhaust system... I forgot it was only like that when cold. In addition, as the block is warming up, our CVVT allows a LOT of cam overlap on the exhaust valve - very much contributing to the build-up of pressure gradients before & after both sets of cats.
Having aftermarket headers and a tune, mine only pops AFTER the whole system has warmed up, and only after some aggressive driving in the upper RPM range - prior to the tune, I was running a little richer and had a lot more popping... the tune has quelled that to some degree but it's still prominent (and sexy as hell) when you stomp on it for a bit, lift and coast down from 5000RPM. It immediately stops when the injectors shut down, and I can restart the fury with a tiny tap of the gas pedal :)
