Who can read Korean? 3.8l GDI = 350HP?
1 reading
3.4K views 27 replies 11 participants last post by  renzo088
#1 ·
hi ya
long story short, going through .kr www's, looking aroud for "numbers" as google translate is as vague as the original text, came be this
hope it ain't old news
any dude with a KR language pack? the mentioning of the 370Z is getting me really worked up!:point:
#3 ·
350 is about where it should be, using basic math puts the 3.8L GDI at ~345-355 crank hp based on the gain the 3.3L GDI V6 got (260ish to 290 something after GDI). Pretty much any turbo engine is gonna get a higher increase from adding GDI because of better efficiency.
#4 · (Edited)
Forgive the newb-ness, but would this replace the stock injectors? or a totally different engine design?
EDIT: looked it up on wiki, looks like a totally different engine!
#5 ·
I would say 370-380.
This article appears to say 5.0L = 400 hp, when Hyundai stated 430 hp, so going with a 20hp lower and 30hp upper range to add on the 350 range. Then again the 2.4L GDI seems to be right on.
My translator can't translate GIF's...cause it's a pic.
#9 ·
it's not technically written,(he speculates a lot of numbers and designs) he assumes the 3.8 GDI with a turbo will produce 450HP because the Porsche 3.8 Turbo produces 500HP
At the end, he adds "All engines will be produced within 3 years" He also states that one or two of these engine descriptions may be different from actual designs.
Too lazy to read, back to my paper for now. Will post full translation after my night class...
#10 · (Edited)
From what I've read, GDI will give at best, ~20% increase in power, when only changing the fuel system, obviously changing other stuff can net better gains. The 3.3L Lambda prototype GDI engine got a ~14% increase in power. The Theta II also got ~14% increase in power when GDI was added (went from 175hp to 198hp after GDI).
306*1.14=348.8
It's pretty much absurd to think it's going to be getting much more than a ~14% increase in power given Hyundai's current history.
#14 ·
Show me one dyno of I/H/E V6 making 300whp and I'll buy it. The only V6 to hit or break 300whp so far that I've seen is SFRs and they had cams and a tune as well.
#13 ·
Very biased and inconclusive for the most part on final numbers...and the bold/italic stuff is someone ELSE commenting on another person's review and being a fool saying some stupid s#%t....but anyways...yea...it says in the end starting from next year and within 3 years all the GDI's will be out for Hyundai...this is old news...came out last year
#16 ·
Hate to back up Promo, but here is one that was posted in the Community Dyno thread. He claim's to only have intake/exhaust before the tune.
*edit: sorry my graph has a few confusing parts,
1. All my runs were with the listed mods with 91 octane.
2. Run 13 was after Arvin's tuning on the dyno.
#17 ·
Well I stand corrected. Hadn't looked at the V6 dyno's in a while. Bout time the V6's are putting down some good numbers. I'm used to seeing the measley 240-250whp with bolt ons that most V6's post. I'm still baffled by the wide range of dyno numbers the V6's are making.
#19 ·
i think there has been a mention of Hyundai putting in newer updated ECUs in the V6's after a certain build date...this could have been a factor in maybe a newer flash to create more power?
#21 ·
should be possible as long as you swap parts of the fuel system and ECU. would it be worth the power..Probably not..
Edit: I take that back, looking at the piston i'm not too sure it would be possible
#22 ·
Why not do some forged pistons while the head is off... Im not so much interested in the proformance gain in this as the efficency gain. I was thinking it be possible swap fuel system and cylinder head and then have it tuned. As long as the short block is the same. If ya have to get new cylinder it isnt all lost. Like my only buyers remorse Im gonna have is when it has DI... Im already planning on buying '11 interior parts and swapping them.
#26 ·
because we have tons of them floating around here lately..:hsugh:
And imagine this, I wasn't even targeting that comment towards you....go figure.
#28 · (Edited)
i seriously doubt it for the v6....the Delphi unit iirc is still missing data to allow full tuning
the easy to crack 2.0t data isnt fully completed iirc and we still dont have a way to tune ourselves.
GdI is a pita to tune (most tuners aren't familiar with it), and as a result more expensive for the tunes.
GDI is nice for leaving it stock. Ill take a pass if im making big mods (turbo swapping etc)
What did he dyno stock? thats very important when it comes to things like this
intake and exhaust putting him at ~294 is bizzare, when other members have intake exhaust and headers and aren't making the same with tunes
