Camshaft Position Sensor
19K views 12 replies 9 participants last post by  aw.tony.aw.tw
It's probably the sensor working as it should and telling you the cam is over advanced. More than likely a cam phaser issue. If a lot of miles may be a timing chain issue. It's located near the engine lift strap on the rear of the motor.
P0014 Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 – timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator
