ok first not starting a war on this just wanted to show it to people ..
so i had my CC clutch setup installed a few weeks ago and had problems with it ... since the install i wasn't able to change gears as quick as before and i also had a problem where the clutch wouldn't disengage completely ... i solved that part by bleeding the line correctly ...
then 2 weeks ago my transmission started grinding .. and the usual vibration that i used to hear while idling was much louder than it was ...
i've spent 370$ on a clutch install.. guys at the dealer put everything that came in the box to make sure it would work correctly .. but it didn't .. they ended up spending tho whole day on my car and decided to split the bill in half because 8hours at 85$/hour is way too much for a clutch install
i went to the garage this morning because the car was literally undrivable
they fixed the car and but i ended up with this
So when they removes the transmission bolt, they tried pulling on it but it wouldn't come out ... something was stuck in there ... they had to put bolts to push the transmission out and then the culprit showed up
TADAA!
This is the brass bushing that comes with the clutch kit ... you have to press it in the flywheel and grease it a bit and the input shaft should spin freely in that bushing instead of the OEM bearing .. but the reality is ... the bushing doesn't fit loose enough on the input shaft so when they pulled the transmission, that bushing was stuck on the input shaft and they had to use a puller to pull it out .. so we ended up putting the stock bearing but the fitment wasn't as tight as they would've liked (because of what happened with the bushing) .. they ended up putting a bit of loctite or something similar to make sure it doesn't get out
so finally .. after spending about 650$ for a clutch install the car is running fine but we can't say if this has done damage the transmission yet
i still have that weird vibration while idling since that problem happened but i really hope it doesn't get worse because my car now sounds like crap at every stoplights
TADAA!
