Hey ya'll, I'm currently dealing with some pretty heavy flutterdump/compressor surge after the new turbo install. I am trying to post a video, but my phone won't upload it and my work network seems to be blocking my ability to upload to youtube.
Anyway, I get flutterdump anywhere from about -5 in vacuum all the way through max boost. I can be cruising in 3rd, at about 3k RPMs, then gradually give it gas, and when I let my foot off the pedal, I get the "ch ch ch ch" of the surge, followed by the BOV release a split second later. The car might go in to boost at maybe 1-2lbs during that push, but more than likely floated around 0pst. Is the BOV just opening late? I have the vacuum lines for the BOV routed off the intake manifold, so everything should be good there. I don't have a lighter spring to try on the BOV at this time, but I am thinking about ordering one. I am running the plain 10psi spring right now. Should I try a 9 or even a 7?
I'll post pics of my vacuum routing around lunch time, and I'll have a video up tonight.
Can anyone suggest other things to look at, other than the BOV, that might help me to eliminate this problem? My automotive epxerience in with N/A cars and this is my first turbo, so I'm still learning here. I'm googling stuff too, but I figured I'd ask here in case there was anything specific to our cars.
UPDATE with videos and images
The videos arent the best, but you can hear the surge when I let off.
if you tube videos don't embed, here are the links:
http://youtu.be/hsv1fzWvprs
http://youtu.be/eWV0BlmwjK0
THE LAST 2 VIDEOS ARE PROBABLY THE BEST FOR HEARING THE PROBLEM
Here you can see the vacuum line coming off the BOV. The BOV T's in to that line, which runs between the MBC and the intake manifold. I am also T'ing the boost gauge off that line.
The T for the boost gauge
And the line that runs to the MBC
