Is there anybody replaced sunroof drain hose?
4.1K views 3 replies 4 participants last post by  Snyper
#1 ·
Hello
My car has water leaking on passenger side footwell and rear roof drain hose space with trunk.
Do I need to remove the dashboard to replace the front hose?
#2 ·
I would check first if the hose actually has a hole in it or is just clogged.
And to answer your question... I don't think so?
Should be able to get at a majority of the hose if you remove the A pillar cover.
#4 ·
Exactly what they both said. Most likely they are clogged a bit. If you use air to blow them out use low pressure and not high. I bought a 6 dollar dryer vent wire cleaner, cut the brush off the end and slowly cleaned them out. Not on our cars but on a cadillac CTS. They are famous for leaking.
If your hoses are partial or blocked completely, water will run down the outside of the hose giving the appearance of a leak.
