It's half the price and you don't have to open the differential housing to replace the gears. I PM'ed more detailed info on what I paid (keeping it private because the seller has other items for sale and I'm not comfortable disclosing negotiated prices).
Here's some info I gathered about the swap so far:
I have been eyeing ebay for one and the average price goes for $750. So I would say anywhere from $600 to $800 shipped is a fair price. I don't have many junkyards near me let alone a yard with newer models so I'm not sure how much a junker would costs.
All together I know you need:
- the LSD gears or the entire pumpkin.
- 2 gaskets
- gear oil
- Tools (I need to buy torque wrenches)
- If you are swapping the gears (internals) then Jay at SFR recommended the OEM shims. Also need another gasket (not sure) and sealant.
- An alignment after completion.
Swapping the gears is added work so I just went ahead and only been scoping out the entire assembly for a direct swap.
I will add the DIY information here too. There is also some cons to having an aftermarket differential like wheel chirping while turning (aka in a parking lot at low speeds). Same goes for welding an open one closed.
Also take into consideration what gear ratio you want to have. I'm staying the same so the only improvement I will have is having both wheels spin at the same time. Resulting in better launches, hopefully better cornering, and less wheel spin...possibly .2 shaved off the 1/4, but this is just a theory. Others are opting for higher or lower gearing for better acceleration, but at a loss of top speed. Gas mileage will suffer a little bit too.
I have not done the swap yet as I am waiting for the mailman, lol. I also will be dedicating a day to this because something always happens when doing installs and they take longer than expected. I believe it should take somewhere between 2-4 hrs to DIY. Others have reported that a shop will take 1-3 hrs. I plan on getting estimates tomorrow from local transmission places.
^Correct me if I'm wrong....This is just info from me reading about this on these threads so my interpretations or understandings may be flawed^
DIY Guide:
http://www.gencoupe.com/articles-driveline/52467-open-differential-lsd-swap.html
