we need higher compression pistons
6.1K views 45 replies 23 participants last post by  2.0TGT
#1 ·
Gen 3.8 has 10.4:1 compression (no doubt to allow for the use of regular)
370Z has 11:1 compression!!
If we could bump up compression to 10.8-11 we'd actually give 370's a run for their money.
Someone has to come out with some pistons!!
#3 ·
id rather have an all motor car than s/c or turbo.
with 11:1 compression, cams, headers, exhaust and appropriate tuning I dont see why we couldnt get 375 HP
Now that would be fun
#4 ·
11:1 is considered stroker territory by most engine builders.
the 350z has a 10.3:1 and the LT1 has a 10.5:1 to put it into perspective.
And to bump compression up to 11:1 isn't as easy as just throwing in taller pistons. The maximum clearance for the stock ones are probably already used, because it has a variable valve timing system.
You would need a crank with a longer stroke, along with shorter conrods and pistons.
#10 ·
the 350Z with 306HP has 10.6:1, s2000 2.0 has 11:1, s2000 2.2 has 11.1:1, 370 has 11:1
If we couldnt reach 11:1, id settle for a few points...10:8 is fine by me. Im sure JE could whip something up if we gave them the measurements
#5 ·
Nah, you don't want higher compression on a turbo car, more boost will beat a 370 all day long.
#17 ·
well since you are planning to keep it NA higher compression would make it easier to make more power but i know alot of us on here including myslef are planning Forced Induction at some point. personally i plan on getting some 9: 1 compression for when save up for the custom twin turbo set i have planned but until then for a quick fix i do plan on putting a small shot of nitrous probaly something small like a 75 shot considering im still running stock internals but i do plan on a full engine rebuild. but anyways good luck with what u want to do let us know of the power gains and everything if you still decide to do it...
#29 · (Edited)
<div class="pre-quote">
Quote de <strong>drdimick</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">All that is not necessary, they can shape a piston to accomadate valve clearance. There are evo pistons that a 10:1 and those 4G63's have the MIVEC system. Like stated above S2K's run 11:1 and runs Vtec, you do not need a stroker kit in most cases to run that high of compression.</div>
</div>Those engines were designed for that kind of compression from the factory. <br>
<br>
Would you want to chance screwing up your heads because the CCVT wanted to advance cam timing?<br>
<br>
You "could" go with domed pistons, but with how acute the cuts would be to meet valve clearances, you inch closer to predestination and thats promoted more by sharp edges in the chamber (valve reliefs).<br>
<br>
EDIT: predetination* <img src="http://www.GenCoupe.com/images/smilies/tongue.gif" border="0" alt="" title=":p" class="inlineimg">
Wrong, the Evo 8 has 8.8:1 from the factory. Again I wouldn't worry about the CCVT, because the pistons are going to be designed to allow room for valve clearance and contour combustion chamber. Stroke has nothing to do with it. 11:1 compression is probably not create a sharp enough edge to heat up enough to cause predetonation. I have seen street card with higher compression.
#33 ·
As far as i know no one makes pistons you need to go with Copper Head Gaskets and mill the head a little bit. If it has head gaskets and not o-rings. Also the largest over bore may help. Since its a factory kit they may have change the pistons to keep same compression. This will get you closer. To go all the way you will need to make a few changes to the stock internals. The valve timing should have enough room to deal with the thinner head gaskets and Head milling. This is common on engine rebuilds and should clear even with the valve timing fully ramped up.
But how can you handle fuel. More Compression will need more fuel. Other changes besides compression will need to be made. May get away with just a fuel pressure regulator.
#41 ·
Just milling down the head or block decks brings its own set of problems.
I haven't really looked into the 3.8 too in depth yet, but some things I've seen in milling down the heads/decks in other engines, is that you add more slack into the timing, be it belt or chain driven, especially if the each bank is single belt/chain driven. In those cases, you would have to use shims on the cam towers or over bore the cam bearing mounts and then use different bearings to correct valve timing. If its just a push rod design link on the domestics then it shouldn't be a problem, but since is it has variable cam timing, I doubt it :p.
#34 ·
Increasing the compression ratio on the GC will probably have to accompany a lower maximum RPM, which would negate any power increases. To increase the CR, you have to either increase the con-rod length or increase the size of the piston heads. Doing either without using lightweight parts will decrease the rev-limit. Light weight parts are a lot more expensive and less tolerant too.
#35 ·
You are making this more complicated than it really is. Bumping up the compression a few points is no big deal and will not decrease your rpm limit.
I know plenty of people who have done this in VW's and Hondas.
#40 ·
You''ll also be dealing with installation, tuning..etc costs as well. so that 5-7k will truly come out to be 9-12k when its all said and done.
a simple piston swap will be much much cheaper than turboing or Sc'ing the car.
the v6 has a displacement of 3.8
The v8 camaro has a displacement of 6.2
The V6 will not make numbers that high with a simple supercharger swap..a SC or Turbo kit will generally add about 90-120 crank HP on stock high compression engines.
#42 ·
RMR had custom JE Pistons made for their mid engine project...they bumped compression up in the 4.6 V8 up to 11:1
This is a very simple mod...once you have all the measurements required.
#45 ·
LOL @ OP
"PLEASE GIVE US THIS 1,500$ MOD TO BE BARELY AS FAST A STOCK CAR THAT COSTS LESS!"
lol. Seriously, high compression pistons aren't going to help, the rods are still weak. You'd need nitrous to make any decent power lol.
You could just get a bottle with a 50 shot and be fine lol.
If you're going to rebuild your engine why not rebuild it compeltely and put F/I on there, or make it a bottle baby V6 (lol fail)
EDIT: Also the heads in the VQ37 flow alot better than these, so it'd be a moot point, the genesis would still have less power and torque.
#46 ·
Not everyone wants to go FI...been there, done that. Your "go big or go home" attitude doesnt really make sense.
How do you know the Infiniti heads flow better than a Gen 3.8? Where is the proof. How do you know the rods are weak? This is your opinion, not fact...lets make sure we make that clear.
11:1 compression, I/H/E + tune would be ~350 HP at the crank, thats the range Im looking for.
