Has anyone blew their engines yet? 2.0t
1 reading
19K views 143 replies 44 participants last post by  pj2.0
#1 ·
Curious who has and at what mileage?
#10 ·
Yeah... That'd do it. At that speed a downshift to any gear would spell disaster. :/ you'd think the transmission would take the blunt if that ? I guess the transmission could take more punishment then we thought.
#12 ·
no... not yet. but when I got my car tuned... it blew my mind!
#14 ·
I seriously hope it's a build date thing with these rods.
#16 ·
Good point I'm may13, 2009 you?
#18 ·
Don't feel too bad Subaru had to recall an entire year and seize sale of cars because they were blowing engines.
Ferraris sometimes have fatal defaults because a bolt or two wasn't installed.
New M3 blow through axles, on normal DD conditions
If you broke a rod you wouldn't be driving around, if you tried the engine would seize from bits of metal everywhere.
They used powdered steel for the rods and pistons. Perfect world it's the best stuff to make anything out of. The reality is that usually it's contaminated in powder form and probably half the engines in existence will suffer.
If you really did blow your engine post your hp and production date. (it's located inside of the driver door jam)
please no jerks who want to lie about even owning a GC
#19 · (Edited)
This may not be a older or newer rod problem. It may be just a certain batch of material they reicieved to produce the rods was non-conforming.
I make medical parts and I have to log where every piece of material I'm making comes from and have material certificates as well. The properties of the metal that were used on certain build dates may be the problem. It may only span a month or so.
Either way if these things keep popping in stock form there may be some kind of mass re-call.
Something doesn't sound right, if you snapped a rod I seriously doubt that you would have been able to drive to your friends house. That's what you did if I'm understanding you correctly.
#22 ·
When you downshifted, did you heel-toe (rev-match) or just clutch in/out? If you didn't rev-match, there's a chance you over revved the engine on downshift. The car's computer would be able to tell you that. Throwing a rod takes serious strength. Now, we all know the construction is not the greatest on the current engine rods, that's to keep the costs down, but a normal downshift, even a quick one, shouldn't be breaking rods.
I've seen engines throw rods before, and you would not be able to drive it. The engine crank would seize up or window the block if you split it hard enough. If the car is driveable, it's more likely a spun bearing or rod knock. Both are usually caused by a lack of oil pressure or over revving. Keep us updated. I'm interested to see what the dealer says.
#25 ·
If he picked it up in July I would bet his build date is no later than May of 09.
Either way, bummer :(
I'm also doubtful it's a snapped rod, since he probably would have punched a hole in the block since it was at high rpm. I'm leaning with the spun bearing comment myself.
#27 · (Edited)
Im not buying the faulty rod. nor build date
If it was a build date issue and hyundai knowingly switched to another composite..because they know that the original material isnt very strong..they they could have set themselves up for a really big potential lawsuit.
If it was a faulty rod issue..then in Beyond redline case the rod would have exited the block with some sort of physical damage (bends, tweaks, Cracks..etc)..the rod escaped their car with no sort of extreme physical damage (the rod came out in the same exact shape & form that it was cast into; no bend, chips or missing pieces...virtually unscathed)
Something goes wrong and the first thing ppl point to is the rods.
Nefairyous, If you blew a rod...your car would not start up under any circumstance..Period.
What 4 people blew their engines?
the only two i know are
Beyond Redline
Hardmack
unless you wanna throw in the one where the engine blew because, the dealership didnt tighten the oil drain bolt...thus running the engine dry.
other than that im not seeing four...unless someone else wants to chime in and inform us of the others
#28 ·
Did we ever hear anything else about BR's engine? Their press release wasn't terribly informative from what I remember. All I've really read about it has been speculation and BR claiming that "it wasn't the tune". Of course, I haven't really seen any good evidence for what happened, so who really knows?
#30 ·
Yep we know it wasn't "high speed" but high RPM is probable depending on what gear he down shifted to.
he is canadian.. 130kph = 80mph and 80kpm = 50mph. So 5th or 4th gear is more than fine. Even 3rd gear probably would have been fine. It all keeps pointing to faulty rods.
#31 ·
Even if he went from 6th to 3rd he wouldn't push the revs past ~6500-6700 if the speed would stay constant, but after he started downshifting, the actual speed of the car would (normally) go down accordingly, thus bringing the overall RPMs down also. This IMHO is not extreme conditions, uncommon yes.
I'll wait and see the results.:squint:
#32 ·
Ditto, same with Hardmacks issue.
We still need to know build date of his car too.
It's possible that Hyundai had a slacker working for a few weeks, had a bad batch of parts, etc... Although if any more 2.0Ts crap out below 270whp, or at stock levels, I'm going to be pretty pi$$ed at Hyundai. Even a crappy single cam D series Honda can hold 300whp on stock internals.
