41 - 60 of 6,374 Posts
Have you installed your pro-kit yet?
I have the pro-kit on my base, and am considering the same wheels as you (in Gunmetal for my Lime Rock Green), so am interested in how yours look with the pro-kit...
Actually I'm in Mexico right now. I will take pics when I get back in about 2 weeks. Sorry, I know how much some of us need pics.:wtc:
3500? works aren't even that much unless you are special ordering colors....
I really like the concave RPF1's or some emotion xd9's with a nice lip. Both of those won't cost an arm and a leg and will look awesome.
I'm thinking 17x9 low offset all around. yummmmm
I want some 17"s that fit over the Brembos.
guys.. need some input please.. will 18x9 +15 fit in the back? The lowest offset I've seen mentioned here on the forums was +18 (with the width of 9.5 I believe) - anyone know for sure if +15 would fit with no modifications necessary? :dunno:
PICS yet?
Can't wait...!!! I want the exact same ones in gunmetal...gotta see...esp. interested in how the offset looks.
Also anyone know of other center caps that fit these? Not crazy about the ones they come with...
Just went with:
5Zigen ZR+250 Matte Bronze on Red coupe
Front: 18x8.5 +25 using stock rear tire - 245/45/18
Rear: 18x9.5 +20 265/40/18
Will post pics when I get them on....
MIne are Fastwheels Predators as follows
wheels-Front 20" x 8.5" offset of +35
Rear 20" x 10" offset of +45
Rubber- Falken 452
Front 245/30ZR20 90Y
Rear 275/30ZR20 97Y
Ill edit in week or two with pics of wheels before and after spacers.
What size spacers did you get? I cant wait to see these on, thats the exact size I am planning for my car and I am unsure of the offsets
I put the WORK XD9 18x10+18 with 225-40's from my silvia on the genesis and I thought they were going to stick out (nicely) for a fender roll/flair because the 18's that come with the car have what appears to be really thin backpads and no lip but instead they were just dwarfed by the car. I will try 19's next but I may need 20's for proper flushness.
Im guessing that the reason I have not seen anyone in Korea or USA with flaired fenders is that they cant get the car low enough?
here is my other 2 cars that are setting the fitment standard for my genesis:
18's are ok, certainly does not look bad but this car has bigger wheel wells than others I am used to. To get that look where the radius of the fender matches the wheel I think the wheels need to be bigger, I will test fit both scenarios, BUT another concern is being able to drop the car enough to bring the wheel lip flush. Needs to be dropped quite a bit.
not sure of the offsets here on this one maybe someone else will?
This one was told to be 18x8.5/9.5 +22
Not sure of this one as the rears look alittle more poke and stretched.. Might be +12? But is perfect fitment to me. Just needs to work the front.
Another one i wish i knew the offsets and specs on:
Idrum2loud is correct when he wrote that spacers ruin hubs. When people add spacers it changes the "true center" of the wheel and puts added pressure on the bearing.. I've seen and experienced it plenty of times..
BUT.... that all depends on how wide the spacers are, and what typeof driving is done.. Typically anything past 10mm with spacers and you are doing some harm to the bearing.. Where I screwed up, and probably where idrum2loud did aswell is going with something larger than 10mm AND using it for track purposes.. But for normal driving, it's perfectly fine..
Idrum2loud was 100% correct.
My .02
good day.
